Go Back   MIG Welding Forum > Welding Techniques > Other Types of Welding
Reply
  #11
Old 12-10-2009, 5:44 AM
graffian
Seer unto the end of his beard
Profffeesionaly made, thats what the billet followers were, they were from Newmans. I don't really have money to have stuff done. My experience of pro stuff isn't very good. Like the followers, no way did they work and the error was pretty simple but you have to consider every part they made should have been the same. There are erros like the pushrod relief is not below the center of the pushrod ball socket, so the pushrod was rigid in the hole!
The shaft is the valve lifter[Newmans follower wouldn't touch the base circle with the valve lifter in place!]. All I am doing is putting the engine back together so it's an everyday ride, not a lot I haven't replaced in the engine. It's a little Velocette.
I have several projects with old engines, needing similar cam followers, none of them are easily available. I originally thought I would simply run some beads of stellite over them and regrind them, I suppose I should give it a try, but I was put off by a yank who runs a comany specialising in hardfacing, he gave me a run down on pre and post heat treatment-not exactly my "I ran a few beads over it, and ground to shape" job. I bought a pair of followers from a bloke with an an ice cream container full of followers that had been stellited, none were usable as was, they all needed regrinding and some were not usable cos of large defects, lots were cracked I was told the bits rarely fall off but the cracks do wipe out cams.
Probably best to make a satisfactory pair in steel and go from there. If anything the thing to experiment with would be forging. Some interesting home forging presses on the internet.
  #12
Old 13-10-2009, 11:57 PM
hotrodder
Senior Member
That's a bit pants! Does the oven at home go high enough for pre/post heating with stellite? Rockers are certainly small enough to fit inside, just pack the missus off for the weekend
  #13
Old 14-10-2009, 8:48 AM
Shox Dr
Senior Member
Quote:
You would never catch me doing anything like that
I like our oven it has a self cleaning function, it looks the door and heats to 500c for 1,2 0r 3 hours, I not figured out what I could use that for yet, but I will.
__________________
If you don't learn something everyday, then you haven't been listening
  #14
Old 17-10-2009, 9:13 PM
graffian
I think the first thing to do is get the hardness of the cams and
original followers.
Reply
Thread Tools
Similar Threads
Thread Thread Starter Forum Replies Last Post
welding titanium tig trainee TIG Welding 17 14-02-2009 6:41 PM
titanium wanted.......... migmag Tools, Materials and Techniques 11 10-01-2009 12:33 AM
Titanium supply JayRS4 The Brew Room 8 23-10-2008 12:10 AM
Titanium welding crayefish MIG Welding 16 11-05-2008 4:51 PM
Can a DC TIG unit be used for silver soldering? no idea TIG Welding 4 05-07-2007 10:46 PM
Powered by vBulletin® Version 4.0.5
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
