Go Back   MIG Welding Forum > Tools, Compressors and Metal Coatings > Paint and Metal Coatings
Reply
  #1
Old 07-10-2009, 10:31 PM
excossack
Senior Member
Default Spraying bare metal
I have some metal sections to paint up.
I going to degrease the metal first.
Before I do a coat of paint, am I correct in saying i need to use some etch primer first ?
__________________
Thanks
John
www.team6.org
www.nnoc.co.uk
  #2
Old 08-10-2009, 8:51 AM
jaykay
Senior Member
no not really,just regular primer.
  #3
Old 08-10-2009, 9:38 AM
rikrobson
Senior Member
Depends on the paint, finish and what environment the sections will be in.
e.g. Hammerite goes directly on metal, couple of coats good to go.
The paint primer will need a key. Etch primer provides this by eating into the surface of the metal.
  #4
Old 08-10-2009, 10:14 AM
joe666
depends on what you are going to paint them with
  #5
Old 08-10-2009, 10:21 PM
jaykay
Senior Member
p120 will give all the key you need
  #6
Old 09-10-2009, 9:16 AM
steveo3002
Senior Member
id suggest you do use a etch primer ...bites onto the metal for a better chance of it all lasting etc
you can lash normal primer straight on . it wont bubble up or do anything strange but wont hold up to abuse so well
  #7
Old 23-10-2009, 12:12 PM
frankieboy's Avatar
frankieboy
Etch primer is definatly the way to go, ive used normal primer on bare metal only to find a few months down the line the paint starts lifting then rusts!
  #8
Old 23-10-2009, 12:36 PM
jaykay
Senior Member
Default jaykay
sounds like poor prep
  #9
Old 21-11-2009, 4:23 AM
McCullough72
Startin' on mine tomorrow. Some surface rust removal. Probably to bare metal but not completely. Primer recommendations anyone?
  #10
Old 21-11-2009, 11:41 AM
jaykay
Senior Member
depends what your spraying,metal wise.
as your in the states,and not all paints are the same as we have here,look at ppg,dumont range.
oh and treat that surface rust first.
Reply
Thread Tools
Similar Threads
Thread Thread Starter Forum Replies Last Post
Bare metal respray ozy Paint and Metal Coatings 22 24-08-2009 9:01 AM
Bare metal panel preparation - Advice Please Chris598 Paint and Metal Coatings 3 31-05-2009 7:33 PM
Hammerite on bare metal Gmwelder Paint and Metal Coatings 14 31-12-2008 10:39 PM
which Primer to used on bare metal? eddie_ma70 Paint and Metal Coatings 5 18-11-2008 3:58 PM
treating bare metal Schakal Paint and Metal Coatings 4 11-05-2008 12:07 PM
Powered by vBulletin® Version 4.0.5
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
