some one posted this on my bike site today apologies if it came from here if not i think its worth the read
makes you think thats for sure
"Yep, I thought I was a goner this time. How simple it was to get into trouble.
After seeing and reading so many warning labels, we tend to no longer pay them any heed. We buy chemicals and sprays at a local parts house and think "How can this be so bad, health-wise, if I'm buying it over the counter?" Here’s how a small whiff of smoke almost dropped me where I stood.
I had a rush job to do, welding four diesel tanks. I had to patch where they were pitted by road salt corrosion.
Normally I spray a little carb cleaner on the spot I'm going to weld, wipe it off, then preheat the area with an acetylene torch to get rid of any solvents. Where I normally get carb cleaner was sold out, so I got a can of brake cleaner and went through my regular routine. To be on the safe side, I even had the shop door open and the exhaust fan on.
I started TIG welding on Thursday afternoon and had no problem at first. But when I started welding across a really pitted area, I found a couple of drops of brake cleaner that were lurking in a deep dimple. As I came close to the cleaner, a small puff of white smoke popped up, and I almost passed out. I made it outside and sat for a while in the fresh air.
After about 10 minutes, I went to the office and sat at the computer to check the warnings on the brake cleaner can I used. That's when my whole left side started shaking for about 10 to 15 minutes. (I found out later I was having a seizure).
When I was able to control myself again, I read the can's warning: "Vapours may decompose to harmful or fatal corrosive gases such as hydrogen chloride and possibly phosgene." After reading about hydrogen chloride, I started researching phosgene. The active chemical in brake cleaner is tetrachloroethylene. When this chemical is exposed to excessive heat and the gas argon, which is used in MIG and TIG welding, it produces phosgene. Phosgene gas can be fatal with a dose as little as four parts per million: basically a single small puff of smoke. Symptoms can be delayed from six to 48 hours after exposure. There is no antidote to phosgene poisoning. If you do survive, the long-term effects can be chronic bronchitis and emphysema.
My breathing still was hard a few hours later, but I felt a little better, so I didn't go to hospital. The chlorine taste and smell in my nose and mouth were still strong. About midnight, I started coughing and my chest started hurting but I thought this would pass after a night's sleep. The next day (Friday), the symptoms got worse and my kidneys started hurting, so I drank a bunch of liquids and cranberry juice. For the next four days, I was constipated and only urinated a lot of clear fluid with no smell. Though sometimes I felt okay, I was really in a lot of pain on and off for the next several days, as well as weak and tired. Then my urine became very dark and smelt terrible.
By the next Monday, nine days after the poisoning, I lost all balance. I was confused and could hardly talk, so I finally went to the emergency room. My symptoms were low O2 level, sugar levels out of control, vertigo and I was hurting badly in my entire chest. I was admitted and put into ICU. My kidneys had probably shut down for those first four days. My lungs were damaged so I had to be on O2. I had to be on insulin to keep my sugar in check. Since there is no antidote for phosgene, all I could do was try to rest and hope I got better. After CT, MRI, EKG and EEG tests, as well as several blood tests it looked like, at least for now, there is no permanent damage. However, the MRI showed fluid in my sinuses and a build-up of fluids near my brain. The phosgene scarred my sinuses, which then became infected. The three doctors I saw said I was really lucky to make it.
After four weeks, it appears that I may have emphysema and chronic bronchitis. I'm on nasal medicine and an inhaler. My sinuses are severely scarred, and my smell nerves are damaged. I still have that awful chlorine taste and smell. I may also have pancreas damage, so I'm now on some stronger medicines.
So why am I telling you all this? I hope to save someone from an easily avoidable sever illness or even death. The cleaning sprays commonly found in thousands of bike shops across the country can be just as dangerous if improperly used. Read the labels and warnings! Look up the chemicals you use. Just because you got away with it before, doesn't mean you won't get in trouble next time."
