Go Back   MIG Welding Forum > Welders and Equipment > Welding Helmets and Safety Equipment
Reply
  #11
Old 08-08-2009, 11:45 AM
matt1978's Avatar
matt1978
http://www.uk.masters-of-speed.de/
Quote:
Originally Posted by Normsthename View Post
If you are using a TIG Welder, make sure the helmet is compatible with it
When I bought my Nexus TIG Welder it would not work with any standard helmets. and like you was getting flashed all the time
I went thru' about 4 helmets, and kept taking them back to the shop for exchange!
I did some research and found that you needed a special helmet to work with my type of TIG welder.
I bought a Speedglass 9200X (I think....) and it cured the 'fault' completely
Andy
Its generally the cheaper Helmets that struggle on DC tig.
Nowadays good quality DC tig inverters have a really smooth output, with very little current ripple and its this ripple or electronic noise that the cheaper helmets rely on to know when to switch on/off.
The larger brands of helmets all do versions which are suitable for tig welding.
I have never had a problem with Speedglas I have used the 9000 series a lot and also I now have a Optrel, both very good bits of kit. Don't think you can go far wrong with either of them.
  #12
Old 08-08-2009, 1:15 PM
Normsthename's Avatar
Normsthename
Senior Member
The standard Speedglas helmet would not work with my TIG welder, and I had to use the more expensive 'X' version
Andy
  #13
Old 08-08-2009, 5:09 PM
TIG Paul's Avatar
TIG Paul
Senior Member
Andy
I had exactly the same problem with speedglass I cant remember the model but for £160 it was pretty disappointing, I sent it back and bought a £60 Sealey, got over 3 years daily use from it, it still works ok but its a bit battered, I'm now using a new Parweld XR 915H, cost less than £50 off ebay, its in use everyday and no problems with flashing on DC tig at all
__________________
Paul.
  #14
Old 02-09-2009, 11:00 AM
Bullyterrier's Avatar
Bullyterrier
So Mote It Be
Andy
I am sure the x is just for an extra large screen and the xx has a larger screen again.
__________________
Gite France
  #15
Old 02-09-2009, 3:04 PM
Normsthename
Senior Member
I think you will find the 'X' Version is designed for working with Invertor TIG Welders at very low amps
Andy
  #16
Old 02-09-2009, 6:15 PM
Bullyterrier
So Mote It Be
Have a look here for the specs for the new 9100 series The only difference between V, x and xx is size.
__________________
Gite France
  #17
Old 04-09-2009, 10:31 AM
cookie munsta's Avatar
cookie munsta
Senior Member
I bought a Speedglass 9002X and it cured the 'fault' completely
Andy
oh ok i don't do much tig, but the one i've got is the 9002x, i've now been recently promoted(demoted) to fab shop. in fab shop it go none too shabby previosly on site with sunlight etc it went crap completely out classed by cheaper brands.
__________________
when in doubt, ha ha ha, count it out!- The Count, who knew? a genius.
  #18
Old 04-09-2009, 1:40 PM
Normsthename
Senior Member
That's strange, I have never had any trouble with my 9002X, it has performed perfectly.
I weld thin steel with a pedal, and even at really low amps it has never failed.
Andy
  #19
Old 06-09-2009, 9:19 AM
cookie munsta
Senior Member
some times on site it would blink as in go dark and go light constantly, batteries were new and i tried all setting combinations, was just frustrating when your welding on trusses etc in situ, and trying to keep a +-2mm tolerence. once the arc was struck it was fine, must have been light variations it confused the sensors, in fab shop it goes ok, i don't do much low amp stuff, so can't say how mine goes.
__________________
  #20
Old 07-09-2009, 7:33 PM
Sparkey's Avatar
Sparkey
Resident Speedglass guru
Forklift flashlights make the speedglass go on and off all the time too....very annoying!
But other than that, i love it works a treat!
The new graphic edition is awesome!
__________________
Sparkey
"Your weld is your signature..."
Reply
Thread Tools
Powered by vBulletin® Version 4.0.5
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
