I started to put my practice sessions to some use recently when I tried to patch up some rust holes on my car, in preparation for the MOT. I'm glad I practised and got a feel for what works and what doesn't, with test strips of metal on a work bench first, but I found the practicalities of actual work on a car to be far, far more difficult.
This is using an arc welder to repair thin body panels, remember. The good news is that I'm having reasonable success in joining metal without blowing holes. Difficulties faced include:
- pre-shaping my repair panels to fit curved bits of bodywork, like the relatively complex panel shape behind the front wheels. This seems like a pressed panel. How can you recreate part of that?
- then, having got something roughly the right shape, getting it aligned and ready to weld is even more difficult.
- next, on this vertical panel behind the front wheel, access is very resticted inside the wheel arch. My welding helmet has a hard job fitting! On the work bench I get by fine without an auto-darkening mask. On the car, I'm already thinking that one of these automatic masks might make life a lot easier.
- and I'm on the verge of seeing that a MIG welder probably is the best tool for such a job. I can get by with the arc welder, but I suspect a MIG welder would be quicker.
I just can't believe you were trying to ark weld paper when you already have a mig
