Go Back   MIG Welding Forum > Welding Techniques > Learning MIG Welding
Reply
  #1
Old 06-11-2009, 9:16 PM
Rod's Avatar
Rod
We all have to learn.
Default Welding without a nozzle
Just been watching a video from Miller,I was suprised that the intructor advised to remove the Nozzle or Shroud when NOT using gas and using Flux cored wire and just use the tip. Anybody out there tried this?. The video is on the internet for all to see.
Rod
  #2
Old 06-11-2009, 9:22 PM
Wozzaaah's Avatar
Wozzaaah
Master tailor
If not using gas then shroud or no shroud shouldn't make any difference other than the shroud is insulated from the contact tip so for those with a less than steady hand using a shroud would stop you arcing the tip against the workpiece.
One benefit would be no buildup of spatter to worry about.
__________________
Woz (Moderator)
'It's goodbye to you my old grey friend, soon your days are at an end,
they'll dig you up, tear you down, goodbye to you - Industrial Town.'
  #3
Old 06-11-2009, 9:30 PM
wyn's Avatar
wyn
Senior Member
There was a picture around somewhere of something like a lincoln gas/nogas mig that came with a rubber cover that was put over the tip when using it in gasless mode. (With the shroud removed)
  #4
Old 06-11-2009, 10:53 PM
R Kraft
Senior Member
Quote:
That would be the Lincoln KH726.
It just screws on in place of the shroud.
Robert
  #5
Old 07-11-2009, 6:21 AM
dugndeep's Avatar
dugndeep
A broken clock is right twice a day
I bought the lincoln one and put it on my welder,a harbor freight gas-less 90 amp,had to grind out the center to make it fit but work's great,don't have to worry about splatter getting into the gas diffuser.
  #6
Old 07-11-2009, 10:00 AM
clevinski
Senior Member
Wouldn't another advantage for gasless be that no shroud gives a better view of the puddle?
__________________
Thanks!
Charlie
  #7
Old 07-11-2009, 3:37 PM
dugndeep's Avatar
dugndeep
Yes ,it does help to see what you are doing with just the gas-less nozzle on there,no shroud,was going to say that in the other reply
  #8
Old 10-11-2009, 9:33 PM
papa-t
I just completed trailer learn to weld project, welded outside with a Texas breeze most of the time. Found flux-core worked great in breeze, it blows smoke away from weld. also no shroud helps ability to see puddle.
  #9
Old 14-12-2009, 8:48 PM
sapperb's Avatar
sapperb
Ya if you aren't using gas, i would remove the shroud. Allows you better visual of the puddle, plus you can get the tip into tighter spots.
Reply
Thread Tools
Similar Threads
Thread Thread Starter Forum Replies Last Post
blasting nozzle spangled1 Compressors and Air Tools 4 23-09-2009 5:24 PM
New nozzle for my 160TM .. robtheplod Clarke 7 09-07-2009 2:47 PM
Nozzle loose skeen Welders and Welding Machines 4 14-08-2008 10:44 AM
Heating Nozzle Archie Tools, Materials and Techniques 7 22-04-2008 3:23 PM
what is a nozzle pin? Saz Buying a Welder 4 03-01-2008 9:14 PM
Powered by vBulletin® Version 4.0.5
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
