Go Back   MIG Welding Forum > Members Section > Introductions
Reply
  #11
Old 07-11-2009, 4:18 AM
Toscane's Avatar
Toscane
Quote:
Originally Posted by pedrobedro View Post
...I see you went for the "low vibration" model, unlike your avatar
This was bigger so...
Quote:
Originally Posted by scarecrow View Post
hi and welcome
1.2mm will be tricky to learn on if you could use of flat bar of steal as a heat-sink behind it copper or aluminum would-be even better and get the smallest rods you can 2mm or less and weld electronegative
the jigsaw looks cool
I was looking for 1.6 mm rods today but surprisingly, couldn't find any so I am going for 2 mm. I'm going to try it without a heat-sink first, to see how badly I need one.
Also I don't think my inverter is capable of electronegative welding, there is no such information on the manual. I'm attaching a pair of photographs from it's manual, maybe it's there but they didn't mention it?
The high-lighted parts are the model I have.
  #12
Old 07-11-2009, 8:01 PM
scarecrow's Avatar
scarecrow
Outstanding in his field
your welder is a a dc Welder with a + and - on the two outputs to weld electronegative you just plug the electrode holder into the - (which is the negative)
to weld electropositive you just swap them around with the electrode holder in + and the earth in the -
electrode negative gives you less penetration which will help for lighter materials
electrode positive will give you more penetration
have a read through Malcolm ark welding library I would post you a link but my computer is acting up and won't copy and paste it should be on the top of the page in the ark welding Forum
__________________
(amateurs built the ark and experts built the Titanic)
Reply
Thread Tools
Similar Threads
Thread Thread Starter Forum Replies Last Post
Help needed SINKA Arc Welding 5 20-07-2009 1:30 AM
earth clamp gets warm why?? intransit_89 MIG Welding 9 02-07-2008 10:54 PM
help needed !!!! frenchdom Projects 3 16-03-2008 5:51 PM
some help needed please Mark_rugby TIG Welding 7 13-01-2008 6:26 PM
Help needed spdunk Learning MIG Welding 11 13-02-2007 9:07 PM
Powered by vBulletin® Version 4.0.5
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
