Go Back   MIG Welding Forum > Tools and Techniques > Compressors and Air Tools
Reply
  #81
Old 13-05-2009, 12:51 PM
rtbcomp's Avatar
rtbcomp
Moderator
Default
Just got back from Halfords with a brand new, paid for! HOF213 oil filter (Metro, K-Series engine). It will screw onto 1/2 BSP parallel for a few threads and then locks (this changes a problem into a feature). The noise level is vastly reduced, I think I'll try this on my Clarke compressor.
  #82
Old 13-05-2009, 5:39 PM
rtbcomp's Avatar
rtbcomp
Moderator
Default
Fitted one to my Clarke compressor. Had to reduce the inlet port from 3/4 inch BSP to 1/2 inch. It's quietened it down noticeable, especially the lower note.
This is a pic of the setup on the Westinghouse compressor:
  #83
Old 13-05-2009, 8:14 PM
eil
Senior Member
Default
Looking good as long as its not choking it,I'm sure it sounds a lot better.
  #84
Old 14-05-2009, 1:52 AM
R Kraft
Senior Member
Default
I've got them on my small compressors.
I first started putting them on compressors in the 80s.
If I needed something larger , I would use one of these.http://www.class8truckparts.com/Flee...B001IXZOJU.htm
There's a lot of options if you use marine,truck transmission and hydraulic filters.
Some have drainback valves and some don't.
Robert
  #85
Old 14-05-2009, 9:40 AM
rtbcomp's Avatar
rtbcomp
Moderator
Default
Quote:
I might fit 2 on the Clarke with a 1/2" T-piece and omit the reducer bush, but it seems OK at the moment.
  #86
Old 06-11-2009, 9:09 PM
penfold
Default
As regards the motor temperature it depends on the rating of the insulation, but generally speaking as long as the motor housing doesn't get too hot to put your hand on, it'll be fine.
Reply
Thread Tools
Similar Threads
Thread Thread Starter Forum Replies Last Post
compressor craig36 Compressors and Air Tools 2 17-08-2008 11:08 PM
which compressor? will-antirocks Compressors and Air Tools 7 29-05-2008 2:36 PM
compressor Haze Compressors and Air Tools 34 17-12-2007 7:28 PM
Skip Divers. all comers challenge zardoz The Brew Room 18 08-11-2007 11:55 AM
Skip Diving rtbcomp The Brew Room 50 24-09-2007 12:12 AM
Powered by vBulletin® Version 3.8.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
