Go Back   MIG Welding Forum > Welders > Plasma Cutters
Reply
  #1
Old 01-11-2009, 2:33 PM
Pikey365
Default CUT-40 Plasma cutter problem.
Well, I started using my replacement cut-40 yesterday and only using it to cut 1mm angle off my trailer. After 3 cuts the OC light came on! I followed the instructions and switched it off for two minutes, turned it back on and no red light, so I went to strike an arc and red OC light came on. No arc! Can anyone advise on a solution please.
  #2
Old 01-11-2009, 3:15 PM
oilcooled :)'s Avatar
oilcooled :)
"the slave"
Default
i have a really cheap cut 40 nd that light never came on and i only cut 12mm thick
  #3
Old 03-11-2009, 1:20 PM
Pikey365
Default
Does not help me a lot? Has anyone got any idea of how to fix these things?
  #4
Old 03-11-2009, 3:41 PM
Wozzaaah's Avatar
Wozzaaah
Champion juggler
Default
You bought it Feb this year so it's still under warranty, get in touch with the seller!
Regarding fixing it, you'd probably have to give it to someone who can diagnose faults at component level, it's not as simple as saying it's 'x' or 'y' component that's failed.
__________________
Woz (Moderator)
'It's goodbye to you my old grey friend, soon your days are at an end,
they'll dig you up, tear you down, goodbye to you - Industrial Town.'
  #5
Old 04-11-2009, 12:05 AM
Rosepuds
Default
Various compoents inside the machine when fail can bring on the oc light. Faults other than compoents inside the machine that can cause the oc light to come on are:
low or high mains input voltage, If you are using a long extension lead or a bad connection in the mains plug / socket could cause the oc light to come on.
Consumables that are badly worn or incorrect or the wrong type could also cause the fault.
I work for tecarc where I repair various machines including the one you have. PM me if you require further help.
  #6
Old 04-11-2009, 8:57 PM
Pikey365
Default
I have sent the cutter to be diagnosed, as this is what the seller requested. Hopefully I will get a working machine back so I can get on with my projects. Keep you posted.
Reply
Thread Tools
Similar Threads
Thread Thread Starter Forum Replies Last Post
Cut 40 Plasma Pat4d Plasma Cutters 5 07-11-2009 10:33 AM
Clarke Plasma King 30Si Plasma Cutter CFletcher Plasma Cutters 6 12-07-2009 11:16 AM
Cut 40 plasma cutter - help! Tractor Man Plasma Cutters 13 06-01-2009 11:49 PM
Plasma cut 40 again Daisy Plasma Cutters 10 23-12-2008 12:51 AM
Powered by vBulletin® Version 3.8.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
