rcx132
Philip
- London, UK
I'm prety concerned with the winch wiring on my Vitara. There's no fuse, it's using spiral wrap to sheath the cable, and the cable is silicone insulated. I don't think winches are supposed to be fused, but couple that with the weak insulation and it's a fire hazard. The winch has some sort of safety device which temporarily cuts out if the current draw is too high, I forget what it's called, it came with the winch.
Can I fuse the winch? I think they draw huge currents though. And suggestions for what to sheath the cables with? I originally used the spiral wrap because it can be fitted in situ and allows easy modding of the cabling and at the time I was adding other things to the cable bunch like diff breathers and difflock air lines. But now it's all done and working I need something safer.
