luke_sibley
New Member
hi just after a bit of advice, im welding new engine mounts into my project car, its its high power iv used a thick steel for the mounts 5mm. but obviously the car is only max 2mm in some places the rest normal bodywork thickness... so basicaly what is the best way to weld these into the car ? because if i go to hot il burn threw the car.. but its got to be hot enough to penatrate the thick steel.. maybe heat with a blow lamp 1st ? thanks guys.
